PC Wont Start
29 Jun 2006
Manchester
hi, ive recently had some problems with my pc...hence the post here...
http://forums.overclockers.co.uk/showthread.php?t=17739380
if you dont wanna read basically some games on my pc crash before the graphics bit but my ram has no problems and my main games worked :s
the problem turned serious when i restarted my pc and it restarted itself just after the post screen, so i re-seated everything, then i got no post, just 2 beeps, then 8 beeps, i searched and found this was a vga card problem, so reseated it, then i was back to crashing after the post screen.
i am unsure what to do next as i have no onboard graphics so cant realy isolate that as a problem, so its either my motherboard or graphics card, how should i determine the exact problem? then hopefully i can try solving it.
p.s. i reset my CMOS with the jumper and still the same problem, pc restarts after post screen.
ive tried different combinations of ram, to no avail, i tried a new hard drive, an ide one, this gets to the 'start windows in safe mode' screen then whatever i select it restarts straight after.
i still have yet to eliminate the graphics card, mobo and psu from the equation, any advice on what to do next? should i just send mobo n g card off for rma n pay the postage just for them to test it?
edit: i put windows cd in and installed xp over vista and this partition is working, yet to install test everything but seems okay.
