- 27 Jan 2005
- S. Yorks
Had an issue, but just put up with it, however now PC won't start.
The issue, when I power on my PC it used to work fine. If I powered it down but didn't turn the wall socket off and wanted to turn the PC back on everything in the case that had an led would light up, fans would spin then turn off...repeatedly and the pc wouldn't boot.
If however after powering down the PC and switching the plug on I could turn the wallsocket back on and immediately be able to power the PC on. I put up with this for a couple of years as it was only rarely I'd have to immediately reboot my PC after a power down so it wasn't an issue.
Fast forward to last weekend and I booted my PC and it came up press f1 to run setup so I thought oh battery must have given up the ghost.
Today I replaced the battery but as soon as I power the PC up I get the flashing of lights as previously described.
Anyway, I've stripped PC and rebuilt it, reset the cmos and it booted to bios, but as soon as I set it up and save and reboot I get to the flashing lights again.
Thoughts on what it could be my thoughts are psu, bit I don't have a spare to check with so would need to buy one - what would people recommend?
Machine is msi z170 motherboard, 6600k overclocked to 4400, evga 1080 gtx, coolermaster 800watt silent pro gold psu, 16GB Ave iron 2400 for ram.
Am long overdue replacing the comp but can't really justify it or if I should really replace with a laptop.
Any thoughts.
Matt
Any thoughts.
Matt
