Just moved back into Uni, set up my computer, and it doesn't start
. When flicking the switch on the back, i.e. the powersupply switch, it makes a loud high pitch noise, sort of like a siren, and the pc wont turn on. Pressing the on switch has no effect, it did turn on once but it just made more noises so I quickly turned it off. The light on the mobo doesn't come on either.
What can it be? It is a Hyper-Type R 530W(Think its 530?)PSU and i've heard bad things about these making noises so thats my first guess. Especially as I noticed a few weeks ago it started making a high pitch squeal but it was nowhere near as loud as it is now (and i cant be certain it has always done this). Also I travelled up in a car so it may have been bashed about a little bit there but it was fairly secured.
Unfortunately no one else has a computer so I cant test parts. So does anyone have guesses to the problem? If it is the PSU any chance it could have damaged other parts as well? Thanks a lot.
