Pc won't turn on?!
15 Feb 2013
Edinburgh
Hey,
So my pc worked on Monday, hasn't been on since and I try to turn it on today and nothing.
No startup, no noise. It's a superflower and the lights don't even come on on its cable ports.
All I do get is an orange light on the ethernet port.
If I use the 24pin connector thing (for turning the psu on with no mobo, for leak testing etc) my pump and fans all come online.
I don't know whats happening
Any ideas?
Same problem as in my crystal ball...
So how about listing parts?
That orange light in there likely means PC gets 5V standby from PSU.
Many motherboards have also LED for that, though that doesn't mean it beign stable enough.
Do you have multimeter to check voltages?
Though "jumpstarting" working means there's at least no short circuit in anything connected to other cables and that those voltages should be inside tolerances because PSU doesn't shut down by itself.
Mobo: Asus prime x370-pro
Cpu ryzen 1600x
Gpu:r9 290x
Psu: superflower 850w 80 plus gold.
I've no multimeter at home.
I tried unplugging the gpu, still nothing.
Took nearly everything out the mobo, no difference
