Hello,
was going to give vantage an "extreme" run tonight, but it wont run, and when and click on 3 d mark, a prompt says: SYSTEM INFO SCAN FAILED: CANT RUN BENCHMARK
It is "similar" in 3d mark 2011 - which won't run the cpu/Pysx test etc (screen goes blank)
Winutilities, and windows info (in accessories) run fine, so it seems "3d mark related".
EDIT,
from future mark it says:
EDIT,
Any one know of this problem?"This error will occur if the System Info was not able to run when the 3DMark was started. When you see a prompt “A Program Needs Your Permission to Continue – Futuremark SystemInfo”, please allow this application to run.
