- 27 Apr 2004
- Doncaster, S.Yorks
Right after trying a few of the lower end headsets with mics, and not being impressed with either how they sound, or comfort levels, ive now turned my attention to the more expensive headsets in an effort to finally found some i like lol.
So my shortlist at the moment is the 350SE's or the 360/363 and was hoping some of you guys would have them and could give your opinion on either one.
Also understand the 360/363 will work slightly better without an amp and decent sound card compared to the 350's due to the ohm or something.
The only thing that concerns me at the moment, is the open design on the 360/363, im not sure how badly the sound will leak out from them. Ive had a set of carcharias for a while and think they are open, but nobody has said much about them in the house.
Dont know if theres anything else i should be looking at. had some creative junk, some Kaves which fit me so badly and sounded flat, carcharias which i actually like the sound and comfort (the older style ones not the new 360/pc).
