Once again I've changed my mind on the case I wouldnt mind buying
Now the PC-7+ and the PC-61 both are really nice but they look exactly the same. It seems that the differences are that you get better cooling in the PC-61? Are the fans included with that worth keeping or swapping for some Ambers for example? and is it worthwile in investing in a fan controller?
Finally are the 2x80mm fans included with it possible to be swapped for one 120mm (i.e the Ambers I mentioned)?
Hope that made sense, didnt to me
Cheers again.
.Now the PC-7+ and the PC-61 both are really nice but they look exactly the same. It seems that the differences are that you get better cooling in the PC-61? Are the fans included with that worth keeping or swapping for some Ambers for example? and is it worthwile in investing in a fan controller?
Cheers again.
