- 24 Feb 2007
is it only my case or is it fairly normal for this case to vibrate? sometimes its fine and other times it vibrates quite badly.  Everythings secure etc but i imagine its the hard drives (4).  They are all in correctly so im thinking its just the case does this with 4 in.  Im gonna put in silent fans and use the rubber screws however i think its pretty limited for hard drives.  Where can you get the rubber grommets that are meant to reduce noise for this size of screw?
the noise seems to come from the top of the case and you can actually feel the vibration. I tried some silencer rubber things at either side of 1 of the hard drives in a 5 1/2 bay and it actually made the vibrations worse
