PC7s from ocuk
Got mine a few months ago pc7 plus ii the one with 2 x 120 mm fans one, 80mm blow hole and mesh section in the left hand side panel (bottom left).
There is a Plus III too, 120mm all round and some other random gayness off the Lian-Li boys
top vent just adds negative pressure anyway, i swear they do it to **** off the owners why bother brining out a PLUS and a PLUS 2 when they could have just fitted 120mm fans alround anyway :confused:
Well it's in the way if you where to run a PC+P 1kw PSU or soemthing along that size!
Nice cases, i want one and to do some heavy mods to it!
Massive Attack said:
mine is coming today with a side panel and cothodes i will make a log and post up ;)
Look forward to seeing it. I'm interested in getting one myself, but i can't seem to draw myself away from the seemingly-better cooling the CM Stacker 832 offers.
seriusly? the cooling in this case id imagine to be quite abit better than the stacker as there is no plastic grills to abstuct the airflow beside the stacker is almost 3 time the price
What I find obstructs airflow is the HDD cage, especially when full...
I currently have draw in from the back so that the CPU gets the cold air, a draw in from the front so that the HDDs get cool, and a draw out the side so that the graphics card can cool, and it removes general hot air from the case.
I'm going to redo the fans so that it's in the back out the front soon, and no side fan, and see what it does to temps, it's currently hot, but then my flat is boiling!
InvG
The price isn't really a concern, and i thought the grills were metal. However, i'm growing to dislike the Stacker 832 more and more. What other good-looking cases are there which boast superior cooling to the 832? The TJ09 only has a single intake fan at the front, with not option of using 4-in-3 bays to add more like to can with an 832 if you have more than one 5.25" drives. The TJ07 is huge, and doesn't even come with an intake fan (at least i don't think it does, anyway). What are the best cases Lian Li have to offer, in this respect? They all seem to be lacking intake fans in the front, or don't allow much room for improvement in this area.
why dont you have a look at the akasa mirage/eclipse/ Lian Li A16 or the PC7
I'll consider it. Isn't the Mirage the same as the Eclipse, just with a different front? Also, the problem i find with these cases is the fact that you can only have a single fan at the front of the case, which means only part of the motherboard gets airlflow. Isn't the TJ09 better than cases you mentioned above?
ok here goes didnt take4 many pics as i just wanted it together
I see you have the 'patent cooling kit' thingy there (theside fan). Does the PLUS II version come with that or is it an extra?
Thanks,
Craig.
