Without bios editing the hard power and thermal limits nvidia have locked on the chip means it doesn't really matter how many phases they have.
If you want constant 2ghz+ speeds you need to be under water or have a fancy for going deaf
True.
All GTX1080Tis are power limited to 1.093v as the GTX1080s.
And given that nobody has broken the Nvidia encryption a year now, do not expect it.
I got a GTX1080 Armor OC last year, chuck at prefilled EK block on it and plugged it in the Predator 360, and was able to do 2190 core 24/7.
But had to learn how to make the Boost 3.0 curve to work. Normal sliders couldn't make it work more than 2120. The main point is to keep the temps bellow 32C so it wont hit the first throttling point. Which couldn't achieve with the Predator 360, was always hitting 36-37C under full load on benching. or else I could have passed the 2200 mark.
But again, you much use the Boost 3.0 curve to have good overclocks to the cards limits.
Something the 99.5% of the owners don't do.
your getting the power limit and voltage mixed up. Power limit is just purely how much wattage its consuming. the boards TDP basically. Say a card has a 100watt TDP and is hitting 99 watts when gaming its hitting that powerlimit. increasing the power limit in afterburner to say 120% means a extra 20 watts the card can consume. It's irelevant of what the voltage the card is running at. The voltage could be unlocked and you could have something stupid like 1.2 volts availible but if the power limit is soo low it does not matter. There is three walls with Pascal. Temp wall, Power limit wall and then the Voltage limit wall.
Now with the FE 1080ti cards you hit the Thermal wall first with overclocking. Put it under water then you remove this problem but you then hit the next one which is the power limit problem. you can increase the powerlimit but you will most likley still hit the power limit as its so low. (Shunt mod can help) AIB cards such as the Zotac which have 2x power limit will get around this thus meaning there is only the voltage to worry about thus meanining in the end your max overclock depends on chip silicon lottery as everyone is restricted by the same voltage.
Now with a better power delivery design and hopefully the silicon gods are nice to you it means you may get anywhere upto a extra 50Mhz overclock. With the zotac cards its going to provide much cleaner power to the memory and core so there is less movement in power delivery and voltage meaning things remain more stable. But its not going to make a massive difference if that's what people are looking for. Better off putting it under water and making sure it does not throttle because of how GPU boost 3.0 works.
Quoted for truth. Unless you are really going to hard mod your GPU and chuck LN2 at it, it really doesn't matter.Without bios editing the hard power and thermal limits nvidia have locked on the chip means it doesn't really matter how many phases they have.
its not. i bet the AMP extreme and possibly the Strix can hold over 2Ghz without being "noisy" it will be audible but probably just a little bit more than your case fans. The 1080ti will be consuming less power than my 980ti did when it was overclocked past 1500Mhz. And my 980ti amp extreme did well keeping it under 70 degrees without being noisy.Quoted for truth. Unless you are really going to hard mod your GPU and chuck LN2 at it, it really doesn't matter.
You could well be right with the clocks but it is still down to being voltage locked so requires a bit of luck with the silicon lottery. 16+2 or 10+2 will see very little difference in clocks.its not. i bet the AMP extreme and possibly the Strix can hold over 2Ghz without being "noisy" it will be audible but probably just a little bit more than your case fans. The 1080ti will be consuming less power than my 980ti did when it was overclocked past 1500Mhz. And my 980ti amp extreme did well keeping it under 70 degrees without being noisy.
For two slow cooler cards it may be different.
Being able to chuck more volts and power at them would be the bigger difference for proper overclocking. Better quality phases and VRMs really would make the difference.Yea that's true but i was just going off what ive seen FE cards do when under water. However they hit power limit problems. The AIB cards especially Zotac wont have the power limit problems. So its just down to like you said the voltage and silicon lottery.
FE cards are 7+1 phase design and from actual in depth looking at the FE power delivery that's actually overkill for this card. But it should allow for more efficiency in the power delivery and allow VRMs to have less workload. 2Ghz - 2.1Ghz is where id expect most AIB cards to land stable when being pushed.
To make them look better and ohh dont worry they make sure your paying for them haha. If thier cards look better then people are more likley to buy them.Seeing as big companies aren't in the habit of wasting money, it makes you wonder why they'd go to the extra expense of the added phases if they don't really offer anything over the FE card.
