What res do you game at?
The 250 MB/sec bandwidth of PCI 1.0 is hardly utilised in games so the 500MB/sec of 2.0will make little if any difference.
You maybe confussing the PCI bandwidth with the amount of video memory required. If you have larger screen with big resolutions, then it's recomended to have larger video RAM.
im a bit confused
so it will definately work but not 100 percent as good as 2.0
which gtx 260 do you reccomend?
Yes a PCIe 2.0 card will work fine in a PCIe 1.0 board, I had my 4870X2 running in my old P35 DS4 for a year with no problem.
PCIe 2.0 has got just as many physical lanes in the slot as PCIe 1.1, only 2.0 has double the bandwidth of 1.1. What it means is each physical lane in 2.0 can transport double the data of each physical lane in 1.1.
So running a PCIe card 2.0 in 1.1 will halve the total bandwidth the card can use with the motherboard to access the cpu and ram. But this all depends on whether the card utilizes that bandwidth capacity of 2.0. If not then there is no gain with 2.0 over 1.1.
