- 7 Aug 2012
Hi there, have recently moved my GPU down to slot 4 on my Asus ROG Hero VI so that the tubing on my 1080 Hybrid is tidier due to length of it and the orientation of rad requiring inlet and outlet be at bottom. The documentation for my mobo wasn't particularly clear as to whether or not it would operate at x16 or x8 speeds. The schematic and the description seemed to contradict itself. Anyway on testing it out via GPU-Z it would appear to only be operating at x8 in the lower slot. How much, if any performance difference would I likely see?
It wouldn't be a huge hassle to move the 1080 back up to slot number 2 (which is defo x16) but might look a bit untidier with tubing etc. Reason I moved it down in first place is that I realised I had rad orientated upside down with in/ out ports at top, which obviously would potentially cause issues with air being drawn in to pump.
Ideally would like to keep it in the lower slot, but not if I am going to see a large performance drop. Cheers for any advice.
