PCI Adapter help.
9 Dec 2014
Gloucestershire
Hey guys, I've finally lost all hope in USB Adapters, so it's time for me to make the move to PCI!
The thing is, I have no idea what size/connection/whatever you call it, I'm looking for, so if you could point me in the direction of some, that would be fantastic!
My router supports 5ghz, so I would like one that supports that frequency if available.
My Motherboard is a 970A-UD3P, and my case is the Bitfenix Comrade-Midi tower.
Thanks for your help :)
It's not the adapter interface you need to consider, it's the adopters power and it's antennae gain. Any USB base dongle with an external antennae will perform essentially the same as a PCI/PCIe adapter assuming bandwidth doesn't exceed the USB port/controller bandwidth limit.
