PCI / AGP etc covers at rear of case
17 Mar 2011
Spain
ok not sure what they are called (if they have a name) but the little covers at the rear of a case you pop off when fitting a grapic/sound card etc, can you by replacements? I need two to cover up gaps but just been through the case section on OC and modding and couldnt find anything.Thought there must be something to stick in there.
Cheers
While you wait for them to come in stock, just put some electrical tape over the gaps.
If you're impatient, they can easily be found elsewhere.
