Do you get any extensions where you put in a PCI E slot which brings it down 2 or 3 expansion slots?
i seen this.
Basicly, iv been waiting for a decent graphics card. Iv saved up my money and the 5970 really attracts me
but it wont fit my case
the 2nd PCIE slot is slightly higher than the bottom of the 5.25 drives.
If theres a way to take out the bays, and replace it with a smaller one, i could get away of useing the bottom PCI E slot to fit in the 5970 if i get one
(i could click buy right now but not beable to use it )
any suggestions on how to fit a long card in my case? i have a lancool k62.
i seen this.
the 2nd PCIE slot is slightly higher than the bottom of the 5.25 drives.If theres a way to take out the bays, and replace it with a smaller one, i could get away of useing the bottom PCI E slot to fit in the 5970 if i get one
(i could click buy right now but not beable to use it )any suggestions on how to fit a long card in my case? i have a lancool k62.
