Pci-e 2.0 graphics
12 Jul 2009
I know this might be a stupid question but I need to ask if before I make a mistake, I have a gigabyte M57SLI-S4 motherboard and I just need to know if A new card such as a 4890 would work?
Mobo has 2 PCI-e x16 slots (8x in sli)
Thanks
PCI-E 2.0 was designed with backwards compatability in mind. I'm currently running an HD4670 in a pre PCI-E 2.0 motherboard, with 16 lanes. The essential difference in the designs is bandwidth and IIRC, some changes in power supply through the PCI port, but it was made so that one could generally use a previous card on a PCI-E 2.0 motherboard or a PCI-2.0 card on a previous motherboard.
So in summary, you should be fine, and it will run at x16 on your motherboard.
