PCI-e 5.0 is dumb
4 Oct 2019
Queens Park - London
Most people would be fine with any SSD, even PCI-e 3.0 or SATA and I’ll stand by that hot take as per the loading times of video games in this video
If you’re a data scientist and have huge data sets of multiple terabytes, then yes, faster PCI-e is better but otherwise you are wasting your money.
Realised that sometime back in 2012 i think, it was always the price and capacity that was the problem. Not the speed which smoked the fastest hard drives that we were using.
You can still benefit when(if) you clone/transfer/backup but games aren't the place to flex the almighty sustained transfer speeds.
Still got an older pc using an ancient ssd, falls over when transferring files but it's just fine for quickly loading up all kinds of older games.
What?
They're useful for video editing or other workloads that take advantage of the sequential speeds I guess. More general use cases are bottlenecked by random read/write performance (RND4K Q1T1 in benchmarks) and have been since like gen 3.
So is that more dependent on the memory controller? Would it not be better to use enterprise SSDs which are typically more durable and with higher I/O performance?
If you're doing video editing casually, enterprise SSDs would be pretty overkill.
On the general premise of the topic, I agree. No hardcore gamer needs some PCI-E 5.0 NVMe SSD.
Mostly yeah, NAND access is inherently not that fast in terms of latency, along with other things like caching, wear leveling etc that add addtional layers of latency compared to say, Optane SSDs with 3D Xpoint memory (expensive).
Enterprise SSD's that are SATA/PCI-e M.2 aren't much difference except they might have better binned NAND and better firmware tuning.
Longevity is where enterprise/data centre grade shine. We have all flash SANs that have written thousands of TBs and not a single SSD has failed.
The performance benefits of NVMe over SATA are realised everyday in data centres, especially when it comes to IOPS.
Longevity/endurance and better data retention etc is quite literally what better binning does. The physical NAND is the same unless we're talking about type, and most enterprise grade SSDs are no longer MLC, they're TLC now, just like high end consumer SSD's.
Obviously NVME drives are faster than SATA, you don't need data centre workloads to make that conclusion. I was comparing like for like, e.g SATA consumer vs SATA enterprise.
I never said it wasn't. I was agreeing with this section and providing a real world example - not sure why your reply is a tad condescending, TBH.
I disagree. Sure, benchmarks can easily demonstrate the difference, but in everyday use there is little perceptible difference to a user for NVMe over SATA. Especially for your average gamer (going with JollyJamma's initial theme).
You do need an enterprise workload to truly appreciate how much faster NVMe is over SATA in real world performance. Few get to experience that, which is the general premise of this thread that super fast NVMe SSDs are wasted on average home PCs.
I'm convinced I'm being trolled. Have a nice day, mate.
Most game are historically made to minimize disk IO as it can be slow. Now most systems have SSD's of some sort, Dev's could lean on disk IO more if they choose. This will most likely happen at some point but its hard to do well on PC, it adds a lot of work. Its easier to just brute force so that mostly what happens.
Same with all cutting edge tech. Not needed for most but will pave the way ahead.
No point complaining about it otherwise you will have something to grumble about when we hit dead ends in progress.
To say PCI-E 5.0 is dumb is.....dumb.
I'm kinda wishing SSDs and M.2 slots using fewer PCIe lanes were more common.
Instead of 2x PCIe5 at x4 lanes, use half as many lanes each SSD, a PCIe5 x2 SSD would run like PCIe4 x4 speeds, while being able to fit twice as many.
The PCIe lane inefficiency annoys me on modern PCs, reduces options of more storage, networking and other things that rely on spare PCIe lanes.
Been running my games from a Sandisk 2.5 SSD for years. Only just put them on a Samsung Evo and noticed no difference.
I've noticed no difference going from SATA3 > PCIE 3.0 > PCIE 4.0 for gaming; to the point I've even gone back and reinstalled the same games on the slower SATA/PCIE 3.0 drives to see - yes I was 'that' bored :P
It's the latest thing to heavily market for the current gen of motherboards and SSDs.
By the time it matters it will be common place technology.
I'm not a hater, the above is just my opinion.
I actually agree with you, despite me being the OP who is slagging off pci-e 5.0.
I love the idea of what pci-e 5.0 can offer if it was implemented properly and in the server market, it is very clever in that it allows the same performance for half the pci-e lane usage.
My point of the thread is that people often think that they need to buy super expensive SSDs and an expensive motherboard or they won’t get a good experience and it’s just not true.
PCI-e 5.0 in its current consumer implementation is basically just a marketing ploy rather than actually useful.
What would be useful is if motherboards came with LED code readouts that specifically show the current post process and what component is causing any issues with the system.
*insert old man yells at cloud meme here I guess*
Benefit now is questionable in most scenarios indeed. But....if the masses buy it and fund R&D and those of us who are more informed dodge early adoption and only buy when theres a need so be it!
The same has been the case since PCI-E 3.0 really and I doubt us gamers/domestic consumers will ever need PCI-E 5.0 before 6.0 is out.
Last time I think it really mattered was having AGP ports!
