PCI-E card won't fit
25 Jul 2004
Hi
I bought a graphics card for my new system, it turns out the card is a low-profile card and the metal plate is a lot smaller than the one on the CM stacker.
Any suggestions on how to make this fit would be appreciated.
Thanks
I just bent it with some pliers. Make sure to use some cloth in between if the points of contact aren't flat.
You can also use a cable tie around the bend part and backplate to make sure the card doesn't go walkies.
