Hi,
I'm building a pc, an additional one to add to my networks of pcs..
I needed a gpu, not for gaming or otherwise I just need it for display purposes..
I would like it to handle vista aswell if possible...
What do you guys recommend? cheaper the better, it purely for display purposes only...no photochopping, gaming or anything else...
If it works out cheaper because it cannot handle vista please spec me 1 which can handle vista and 1 that cannot...
thanks a lot
cheers in advance..
thanks a lot
cheers in advance..
