PCI-E / PCI question
30 Jan 2007
firstly could some one explain the difference to me and does a PCI-E need a PCI-E slot or will it fit in a PCI slot (but would lose speed)
think it might be a dumb question just checking
regards
8baller said:
wicked thanks for the quick reply
can you get PCI cards that have pixel shader 2.0? if so can u recommend a cheap one
thanks
I doubt it, PCI videocards are a couple of years old, if you have a mobo that has no PCI-E or AGP slots for videocards I guess the system is quite old?
I remember I almost made this mistake with a friends eMachines PC a while back, almost bought a PCI-Express Graphics card by mistake, when it only had PCI and no AGP ports!
