PCI-E Riser
29 Mar 2003
Norn Ireland
Just wondering if anyone is using a PCI-E riser on a 5080/5090 card.
I have a Fractal Design Flex VRC-25 which I was using on my 2080.
I can't use it at the moment as the 5080FE is so big it won't fit in the case with the Noctua NH-D14, so just plugged in the standard PCI-E slot.
Briefly tried a 10cm gen 4 riser cable with my Palit 5080 in a gen 5 PCIE slot and was getting weird issues so just ran the 5080 in the gen 5 slot instead with no issues.
I probably needed to mess around with bios settings to make it work but not too fussed for now as waiting for a water block anyway.
I am using my 5080 in a Meshlicious case, I just needed to fix the PCIE to gen 4 in the BIOS, otherwise leaving it in auto will cause various issues.
No problem, thanks for the info
I've just found a AM4/5 adapter for my old water block that was on the 8700K so might put it on the processor and try the riser later.
I'm using a nzxt gpu mount for my 5090..
