Im having a bit of a problem, using gigabyte 970a-dsr board with 7990 GPUs.
After shutting down and restarting once, one of the pci-e slots is not detecting a card. It is doing this with multiple cards so not the GPU which is at fault.
It is powering them up, but not showing up once you turn the computer on. Is it likely that the slot is broken or could it be a setting somewhere that has changed?
Any way to check?
Many thanks,
Any way to check?
Many thanks,
