Posted in the graphics section but, I think it may be an issue other than the card itself.
EDIT:
Seems this guy had a very similar issue, Reseting the CMOS apparently did the trick for him however, I have tried this and still X4 !
I just noticed last night my card was running at X4 instead of X16 when i looked at CPU-Z:
I'll list my specs just now
GA-P55-UD5
Intel I5 750
Sapphire 5850
Intel X25-M 80GB
WD Caviar Green 1.5TB SATA-II
Corsair HX650
Maybe this has happened when i installed Windows 7 ?
Definitely installed in the X16 slot. No other expansion cards installed.
In the BIOS, Init display was PCI when the operating system was installed (Should have been PEG).
Changing to PEG doesn't alter what i see reported in CPU-Z - Still X4
I know this board shares bandwidth, I only have the one graphics card installed. I uninstalled it, Cleaned the contacts and reinstalled with no joy.
From what i can tell, This MOBO has SATA running off the P55 chip and GSATA which i guess is the Gigabyte SATA chip.
My SSD and HDD and DVD-RW run on the P55 SATA chip, Nothing at all on the GSATA (Won't boot if i disable this) controller.
I don't have any e-SATA ports in use either.
Anyone got any idea what is going on ? Any advice ?
EDIT:
GA-P55-UD5
Intel I5 750
Sapphire 5850
Intel X25-M 80GB
Corsair HX650
