PCI Express bandwidth
6 Apr 2009
Liverpool
ok been reading up on boards for a new one and came across this
(Note 2) For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16_1 slot; if you are installing two PCI Express graphics cards, it is recommended that you install them in the PCIEX16_1 and PCIEX16_2 slots.
(Note 3) The PCIEX8_1 and PCIEX8_2 slots share bandwidth with the PCIEX16_1 and PCIEX16_2 slots espectively. When PCIEX8_1 is populated with an expansion card, the PCIEX16_1 slot will operate at up to x8 mode; when PCIEX8_2 is populated with an expansion card, the PC IEX16_2 slot will operate at up to x8 mode.
Now i am using the pci express x8_1 on my board so this means the pci express 16 _1 which my graphics card is in is running at x8...is this bad for my graphics card performance being a at 5870...anyone got any ideas thanks.
Aslong as its PCI-e 2.0 spec (check with GPUz) then a 5870 won't be in any significant way held back by x8 speed.
there is barely any noticable difference between crossfire or SLI at x16, x16 and x8, x8. it was tested with some high end graphics cards (GTX580's i believe) and there was literally no difference in framerate when the games were going at maximum graphics.
i assume this is what you are doing, and you dont have something else in the first PCIe x16 slot
i have my 5870 in first 16_1 slot then my asus xonar in the 8_1 slot which reduces the 16 slot speed to 8 i believe.
