- 5 Apr 2008
Hey guys,
Both in the BIOS, and the AMD driver it says it is running at PCI-express 2.0 x2 mode.
My motherboard Asus H81l-PLUS has only 1 PCI-e slot and that is 2.0 x16.
Im using a Sapphire R9 380 with a Corsair RM550 power supply. I made my own case in which the graphics card is parallel to the motherboard, hence i am using a riser cable (but cant see why this would be the cause).
Things tried:
Re-seated gpu (with riser cable).
Flashed Motherboard
Reset motherboard to defaults.
Set motherboard pci-e speed to '2.0'
Set motherboard bios to high performance mode
Set windows to high performance mode
Things not tried:
Put gpu directly in motherboard without riser (would mean completely dismantling PC to fit it in).
Using a 'powered' riser (with a molex connector). From what i have read this shouldnt be necessary and is usually used to give PCI-e x1 slots extra power to upgrade it to x16.
EDIT:
Worth taking the CMOS battery out?
Things tried:
Flashed Motherboard
Things not tried:
EDIT:
