- 10 Aug 2009
- Banbridge, N.Ire
Just about to rebuild the PC and realized that as it's been out of action for so long I had moved my router downstairs to hardwire the PS3.
Problem is, I am looking to move the office room around and the phone line is going to be on the other side of the room compared to the PC. So I'm looking for a cheap fix.
I have seen the PCI-Express wireless cards and they look like just the job.
Can anyone answer a few questions though.
Are they easy to install? I've never had to install a network adapter before.
Good reception? Would I be better with one with a aerial on a cable extension or are they OK with just the built in for the sake of home use?
Do I really need N, or is G just as good if im running 10meg broadband?
Thanks in advance any any other advice or recommendations are greatly received.
