PCI Fan controller
26 Mar 2004
Looking for a fan controller to control 3-5 fans, but don't want it on the front of the PC.
I've found the Lian Li PT-FN03 which controls 3 fans.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-220-LL&tool=3
Problem is it only reduces them to 65% which is I guess 8V.
I'm really looking for something that could do 5V out the box.
I also found the Fractal Design Fan Power Splitter, PCI. which outputs 16 connections ranging from 5v to 12v. Not ideal either as first it can't be adjusted on the fly.
Any alternatives.
