PCI Gf2 MX400
6 Feb 2004
Toon
Have one of these, XFX 64Mb Version, to put in a Media Centre. If I'm not going to use 3D at all do you think it would be safe to disconnect the fan? The case has very little airflow.
Thanks
my plastic read me box of a pc has a MX400, it think its by bfg, but im not sure cause there isnt any stickers onit with the manu name onit. mine has a passive heat sink which is hurrendously small (i think it might be plastic aswell), i wouldnt be suprised if i found out that i did nothing and it was just there for show.
If urs has a fan onit i suggest keep the fan on, unless u where planning to buy a card for ** Media Centre take it off and see what happens.
Azza said:
my plastic **** box of a pc has a MX400, it think its by bfg, but im not sure cause there isnt any stickers onit with the manu name onit. mine has a passive heat sink which is hurrendously small (i think it might be plastic aswell), i wouldnt be suprised if i found out that i did nothing and it was just there for show.
Better edit out that sweary mate. :rolleyes:
Sorry, a little unclear -fan is knackered. Gonna try it anyway, just wondering what you thought. Im guessing it will be OK until the summer...
Maybe put some passive cooling on it, Just get an old small heatsync and some thermal compund that dries hard and jobs a goodun.
I remember my old MX440 only had a rubbish fan, I bet it would be fine with a small heatsync on, a heatsync is a LOT better than just nothing.
