pci lane question
28 Jan 2015
motherboard- Asus Maximus XI Formula
CPU- RTX3090
can I stick the GPU in the second PCI slot- is stated 16x- as my onboard sound is broken and I need to add in a SB card and the only slot is above the first PCI slot and wouldnt fit with the size of the GPU cooler
Its been years since I had to use a sound card and not sure it is still an issue these days
Short answer yes. But some motherboards limit the second PCI-E slot to 8x. Your manual should tell you. Saying that will not make a massive difference anyway.
USB sound cards are also an option like the Sound Blaster X3.
Have got an internal SB AE-5 plus to hand so cant do USB or external
So I should keep GPU in lane 1 and put SB card in lane 2?
Thanks for that!:D
Thanks for that!:D
Looking at that motherboard.
Stick the gpu in the top slot (slot 2) and the sound card in bottom slot (slot 4).
