- 29 Mar 2005
- Mansfield
Is there any way I can enable a PCI lock if the BIOS does not automatically enable it? Basically I have updated the BIOS due to my new SATA2 drive not being compatible with the old BIOS. After doing this there appears to be no PCI lock because when I ramp the frequencies up using clockgen the PCI frequency increases as well and it didn't before. This means that basically I cannot overclock at all which is a big blow.
Can you lock it down manually?
