pci network card
18 May 2010
in my new build i used one of the ocuk value pci wirless network adaptors. so far it has been Verry unstable, not always detecting my network and when it does it doesnt always connect. it is an N series adaptor and a bought a new N series router to see if it would help as i had a G series b4. it has helped slightly but i can still only connect maybe half the time. i noticed on the packaging it says it provides a 32bit pci interface, i am running win 7 64 bit, could this be the problem or do i just need a new card anyway?
If you have the correct drivers installed it should be OK.
I suggest you email the OCUK support team / sales about it - a few people may have experienced this or they may refund.
