I can't decide which will suit my needs better. I'm a Sound Engineering student and really need a decent soundcard to do some recording. I always hear that the E-mu 0404 USB is recommended, so i've been eyeing it up, i still have some doubts though.
I'm not 100% sure whether a soundcard will fit inside my computer, i want to keep the heat down in there too. If i did have one i wouldn't be able to use it on other computers (quite unlikely i would though to be honest), but on the plus side they are cheaper than external soundcards, neater and faster i assume.
I have a 'cracking' problem with my current onboard sound, it can usually be fixed by restarting the computer, however it will return after the computer has been off a long time, i'm guessing this is something to do with the buffer time, anyway, would having a USB/Firewire soundcard fix this or would it have to be an internal card?
Can you use a USB/Firewire soundcard like a normal soundcard? i.e. You can listen to various sound based applications through it at once - i heard you can only use them through one application at a time.
Concerning internal cards, the ones which have a drive bay extension for plugging various input sources in seem like a nice idea. Any recommendations for a decent music soundcard outlining the above with capabilities for gaming too?
Cheers, sorry for the long post.
