Hi folks
I am getting gpu core temps of 58c idle and 80c load on my 6800GS fitted with the Zalman AluCu VGA cooler set at silent, and an ambient temp of around 42c.
Am I right in thinking that is a tad too high, especially on load?
Most of the cooling solutions I have are designed to be silent, and I really don't want to set any fans to 'normal' mode.
I have an Antec Sonata case with a solitary 120mm Akasa amber shifting the air out the back - also set at its lowest setting, but I suspect I may have to turn it up to get that hot air out...?
Anyway - I have been looking at the Akasa system cooler (AK-SB-BK ) which fit onto a spare PCI slot - are these any good?
It states on the website that they produce a noise level of 25.24 dB(A), but I would like to hear first hand experiences if anyone has any that they'd like to share
Thanking you
Thanking you
and 2 rear fans. Prior to fitting a HDD cooler, my HDD's would slowly heat up until they were at about 50C which was a lil too hot. After fitting the HDD cooler, it cooled both of them down from 50 to about 35. That was a big difference.
look me up on my profile and send me an email mate - long time no speak!
