29 Apr 2009 at 19:16 #1 kkelly kkelly Soldato Joined 8 Oct 2003 Posts 2,919 Location Glasgow Hi there, Does a card exist that allows you to turn a standard PCI slot (P4 box) to SATA2 connections? Thanks !
29 Apr 2009 at 19:25 #2 racerboy59 racerboy59 Associate Joined 4 Mar 2009 Posts 450 of course there is. just do a search for pci to sata. actually nevermind. the standard PCI - SATA adaptors are out of stock now. Last edited: 29 Apr 2009
29 Apr 2009 at 19:28 #3 kkelly kkelly Soldato OP Joined 8 Oct 2003 Posts 2,919 Location Glasgow Hi, Most of the ones ive found dont say there not PCI - X Thanks
29 Apr 2009 at 19:31 #4 J.B J.B Soldato Joined 16 Aug 2006 Posts 5,924 Are you after PCI-X or PCIe, the PCI-X standard never really took off. What you need is a PCI SATA controller. A lot of them come with RAID controllers as well.
