PCI TV Card needs ariel. Options?
18 Oct 2002
Behind you... Naked!
I just got hold of a Laptop internal PCI TV Tuner card.
I was 50-50 on it, and so I simply chucked it into a test Laptop, and sure enough, it didnt kill anything and so I have put it into a better Laptop to have a good play about.
After some fiddling about, I cannot get a signal to it, and I suppose this must be because there is no arial, and so I have had a look at the card and sure enough, there is a single connector on there that is the same as a WLAN cards connector... Tiny little snap on thingy.
I see no reason why I cannot try to connect one of those, but I dont know, and so I wont risk.
But my question is simply this :- Can I buy an antennae / arial for the thing thats specifically for TV cards? I have had a look in a few places, but Wifi ariels are all I seem to be finding, not TV ones?
The device I have was a git to find drivers for, but its now working on ASUS 7700D in Windows 7 and both JRiver and MCE see it just fine... Just dont tune any channels. Also kaffeine in Sabayon and Mint both saw it and did teh same.
The card has 2 numbers
G0948030
MC770AV1109N004960
Thats all I can get from it Im sorry.
Any help would be great.
Thank you.
Yeah, it looks like it does from here!
I have since found a few bits of info about various arials ( how the heck do you spell it properly? ) but I am kind of stuck in only being able to have some form of internal ariel as none of myu laptops have an obvious wayt that I can connect an eternal one without serious wreckage to the case.
