15 Sep 2020 at 19:35 #1 Sparky Sparky Soldato Joined 23 Nov 2004 Posts 9,153 Location UK Hi Looking at buying a pci wifi card. Any recommendations?
15 Sep 2020 at 20:10 #2 bremen1874 bremen1874 Soldato Joined 20 Oct 2008 Posts 12,081 Actual old-style PCI or PCIe?
16 Sep 2020 at 05:58 #3 Sparky Sparky Soldato OP Joined 23 Nov 2004 Posts 9,153 Location UK bremen1874 said: Actual old-style PCI or PCIe?[/QUOTE Oh yeh! PCIe Click to expand...
16 Sep 2020 at 21:34 #4 passey89 passey89 Soldato Joined 10 Nov 2011 Posts 4,100 Location Telford Depends on your router. Which router do you have? is it Mimo? 2x2, 3x3 or 4x4? I have the asus rt-AC86u and have it paired with Asus ac-68's and i manage to get 550mbps down and 37mbps up over wifi
16 Sep 2020 at 21:48 #5 Sparky Sparky Soldato OP Joined 23 Nov 2004 Posts 9,153 Location UK I have a VM Hub 3
16 Sep 2020 at 22:01 #6 passey89 passey89 Soldato Joined 10 Nov 2011 Posts 4,100 Location Telford Sparky-F1 said: I have a VM Hub 3 Click to expand... 2.4ghz 2x2 5ghx 3x3 then the asus AC-68 would work then esp on the 5ghz you can expect about 1,300mbps max xfer speeds if i remember correctly . edit. according to web 450mbps max on 5ghz though on it.
