- 28 Nov 2012
- Merseyside
I'm in the process of upgrading my system. I am going from an AM3 Athlon II to a 1055 i7, and a GTS450 to a GTX570/80 or 670/80, possibly in SLi but I need some advice on PCIe bandwidths as I don't really understand them..
I'm looking at motherboards for around £120 that support SLi, but here's what's confusing me...
"Supports 1x PCIe 3.0 at 16x or 2x PCIe 3.0 at 8x"...
Won't one card running at 16x be the same as two running at 8x, as the motherboard is allowing half the bandwidth.
Or... would two at 8x be faster, because something tells me that PCIe 3.0 can support a much, much higher bandwidth than most (maybe all) modern GPU's can possibly support?
(I'm considering the ASrock Z77 Extreme4 by the way)... If anyone has suggestions, please keep it reasonable. I don't have stupid amounts of money to spend.
Thank you!
Thank you!
