- 14 May 2012
Hi all,
I have an Asus Rampage IV Extreme with the following:
PCI-AC68 wireless card
2x GTX Titans
1 Asus Xonar Phobeus
Since I'm running all of these does it really matter which PCIe slots I'm using?
Previously I was running just the titans and had them in 1 & 4 as recommended in the manual for x16/x16 operation however with 4 PCIe devices I assume that this will only be running at x16 / x8 (with the other 2 devices running @ x8).
Thus if I move the GPU's to 1 & 2, then use 4 & 6 for the other 2 devices this shouldn't make any discernable difference... should it?
As a side note it's a 4930k so has 40 PCI-e lanes.
2x GTX Titans
