So I am soon to be upgrading my now very old X58 system, replacing the 3 X GTX 285's with a single 980 Ti. Along with an X5675 and 12Gb RAM.
This system was originally built for me. Looking through the Bios settings I have noticed that the PCIe is clocked at 110MHz. I have read that you shouldn't overclock it and instead lock it at 100MHz, however mine has been fine with zero problems for around 8 years. I think this was possibly done because of there being 3 GPU's with the 3rd slot running at 8X in this configuration.
So I ask, when I do the upgrade, should I knock it down to 100, or leave it as is. Are there any performance advantages of it being higher, some say yes some say no. Some say it increases stability overall when clocking the CPU, which I will be doing.
Thanks.
Thanks.
