Pcie Power Extensions?
3 Oct 2004
Does anyone know if there is such a thing as a 6 pin to 6 pin PCI-E power plug extension cable? Ive been looking around and i cant find any reference to one, i know you can get a molex to 6 pin converter but this isnt ideal. Ive just got a 7950gx2 and i cant plug it into the 6 pin plug because it wont reach. Anyone got any ideas?
Why is the molex to PCI-E not ideal, it would reach then. :confused:
If it means you have to unplug something to free up one of your molex's for it, then just plug whatever you unplugged into the other molex you get on the molex to 6 pin PCI-E as thats what the other molex is for.
