I wasn't getting a display signal with a 6800xt phantom gaming that I bought used, when my 2060 was working fine.
I took it back to the store and they tested it as working.
I then took out the pcie riser from my thermaltake core p3 and put the 6800xt in directly and it worked.
However still I want to run the card mounted vertically as I had to move my radiator out of the way to test it directly into my mobo.
Can anyone recommend a decent riser cable that may be more likely to work? The one i've been using came with my 5 year old thermaltake core p3.
