- 7 Sep 2020
I'm buying the parts for a system build and I need some advice on motherboard choice. Now ideally I want to get a TRX chipset to take advantage of the quad channel memory support because my computer is used for way more than just gaming.
My issue is one of spacing. I've got 3 other important cards besides my graphics card, those being a Soundblaster AE-5 (PCIe x1), Intel X520-SR2 (PCIe x8) and Adaptec 8805 RAID card (PCIe x8).
The problem is, that most TRX chipset motherboards come with only 4 x 16x PCIex slots and if I put in a 3 slot graphics card, I think it will restrict me using the second 16x PCIe slot. Both the Intel NIC and RAID card both put out a lot of heat and I do mean a lot, so you ideally want some separation between these two cards and probably any other card too.
Is there any motherboard that I can buy that will give me at least a slot clearance between all these cards? Obviously the motherboard will probably have to be eATX. I just don't want a hot graphics card coupled with a roasting NIC and RAID card all bunched together.
