Pcie split cables on single rail psus
5 Feb 2022
Knowhere
I read somewhere that single rail psus meant you didn't need to use 2 separate pcie cables for gpus, and that daisy chained/split cables were fine.
However, the ltt techquickie says only the 5.5v and 3v are split from the 12v, making me think the 12v is under heavy load regardless of single or multi rail.
I still use 2 separate cables for my card. Theoretically, I have 6 cables (3 split) but I take it I can't run dual 3090s with them at 850w.
No. I wanted to know whether split pcie cables mattered on single rail psus, and why nvidia recommends separate cables.
8 pin pcie cable has a rating of 150w if you use both connectors of a single pcie cable the max draw is still 150w, split rail single rail has nothing to do with it.
One reason is that even though single rail PSUs are less likely to trip (due to spikes) than dual rail PSUs, you're still drawing a lot of power through a single cable (and there are twice the connectors, if the PSU is modular) and that produces extra demand (and resistance) through the wires.
You're right that the 12v rail is under heavy load regardless, but they're designed to deal with that and how demand is so variable with modern GPUs (assuming they're not group-regulated).
