Will the new 8600gts
http://www.overclockers.co.uk/showproduct.php?prodid=GX-126-AS
Fit inside my pcv300?
My 7300gt almost touches the floppy bay, only because its a very tall card.
From the picture, it looks about the same size as the 7300gt
If not... What do i need to use to remove the floppy bay?
EDIT: Since that card is DVI only...
http://www.overclockers.co.uk/showproduct.php?prodid=CB-127-BE&groupid=701&catid=48&subcat=792
That should work fine with my monitor?
Asus 19inch widescreen btw
