PDA remote control software
9 Jul 2005
High Wycombe
I used to have a HP Ipaq 2210 PDA with a really useful programmable IR remote control application. I upgraded (as my dog ate it) to a newer version (4700) but it doesnt have the software on it.
Can anyone reccomend/name the program and possibly post a linky to it. Have done numerous searches but have no idea which ones are any good (the old program was easy to use, could do macros etc)
Cheers
MMM, it seems you cant buy the software - you have to purchase a device that is "enhanced" with NEVO. Any other ideas?
No other ideas, sorry, I only knew it was Nevo because I too have the Ipaq 2210, seems strange that you cant buy the software individually.
Cheers, been looking at loads of others, eally could do with one that does both wifi and irda - that would take care of all my needs :D
TBirdUK said:
thanks, will it work my tv + sky etc? Am downloading the trial now.
Sorry for the thread revival, but wanted to know how you got on.
I'm itching for some new software to play with and not sure if I should try something else (other than salling clocker) or not.
Have you tried it with the MCE script?
