pdo connection status turned into a variable to echo elsewhere.
11 Oct 2008
Hey guys,
I am currently using the following code to connect to my database and to display custom messages for if it has connected to the database or not.
I would quite like to display these messages in my footer.
I was wondering if its possible to turn the messages into a variable to echo them in the footer? Thanks for any tips.
PHP:
$hostname = 'localhost';
    $database = '';
    $username = '';
    $password = '';
      try {
    $dbh = new PDO("mysql:host=$hostname;dbname=$database", $username, $password);
      echo 'Connected to database'; }
      catch(PDOException $e) {
      echo 'error connecting to database.'; }
      error_reporting(0);
18 Sep 2003
PHP:
    $database = '';
    $username = '';
    $password = '';
    $db_connection_status = '';
    try {
       $db_connection_status =  'Connected to database';
    }catch(PDOException $e) {
        $db_connection_status = 'error connecting to database.';
    error_reporting(0);
Then in the footer where you want to display the message:
PHP:
<?=$db_connection_status?>
