peer guardian vista 64
30 Nov 2007
can anyone suggest a similar program to peer guardian 2 that will work under vista 64
it seem that peer guardian 2 isnt vista compatible :(
Its an unsigned driver, so you can't run it in 64-bit.
I'd also like to know, as I was going to make a thread like this too. I tried following the instructions on the site, but nothing.
Not at the moment i was reading on their forums they need to purchase a license for some vista software before they can make the 64 bit version and seeing as they run completely on donations i dont see it happening any time soon :(
I dont see why not if every that used it paid $1 or £1 then they would easy make the money.
But the problem is everyones wants everything FREE.
