Yeah thats what i belive it does ,is it ok to use ,ie is it full of Adverts etc ??jegz said:afaik its for stopping "unwelcome" connections to "certain" ip addresses![]()
Ok i will give it a go ,so can you switch it off and only use it for *cough* certain reasons *cough* nug nug wink wink ,if you get my drift ..jegz said:Not at all i have used it in the past its really for *cough* certain reasons *cough*
I never found any SPy/Ada/MAlware that came with it tbh. give it a go. iirc i stopped using it because it was using up bw/resources or something :S![]()
jamjar said:Ok i will give it a go ,so can you switch it off and only use it for *cough* certain reasons *cough* nug nug wink wink ,if you get my drift ..
jegz said:Yep
I dont bother basically cos i cba cos it blocks webpages sometimes iirc![]()
AthlonTom said:Blocklist managers such as PG2 are not essential but are sensible - you won't be able to connect to anyone who may be acting on the behalf of the MPAA or the RIAA (as long as there on the list). This isn't massively essential in the UK as they tend not to be able to really go for UK residents. But it will stop some (Not All) torrent killers, this works where by said companies seed the torrent with massive amounts of bandwidth but they only upload empty padded out packets, but the checksum is the same as the original chunk of file, your client will not report any errors because as far as its concerned theres nothing wrong with what you getting - only when you run the file will you find out you've been had - and by then you too have uploaded some "empty" segments. You don't have to run PG2 if your downloading Pron, Games, Apps, or TV Eps. No company has taken any action against down/uploaders of these types of material (yet) other than requesting torrent removal or seeding fakes (Desperate Housewives & 24 are the two most recent examples).
AthlonTom said:The UK's ISP's are currently highly unlikely to give out your details to any organisation - though it is within there right to do so, they won't. The UK's Broadband market hasn't hit saturation point yet and P2P is the biggest driver of Broadband takeup - Your pretty safe until this changes.
AthlonTom said:If you want to be free of any of this type of hassle use Newsgroups - pay a small fee, download faster, be more annoynymous and you get to avoid a lot of the idiots that use BT these days.
