PeerGuardian alternative mirror?
26 May 2009
The Phoenix Labs' link keeps timing out. Is the Sourceforge one a working issue for Win7 x64? There's no version choices there, so I don't know what to do. I got a torrented version, but it won't load properly. All it does is sit in my system processes eating 88MB RAM.
Is it the same thing? It worked fine, but didn't give me the huge block lists I used to get from PG. I'm mainly looking for something to stop BT strangling my P2P transfer speeds.
So it does the same thing? I should be using PB over PG2? Anyone know if it'll stop BT sucking the life out of my connection for 12 hours every day?
I think you're confused.
This software stops people connecting to your PC from certain IP addresses known to belong to the large Media companies etc.
If your torrent d/l is slow on BT then this is because your connection is being 'traffic shaped' or 'port throttled' which is effectively the same thing; BT know what you are doing and are restrciting your bandwidth.
The way to get around it is to use a torrent client like uTorrent and switch the encryption on. That way you should get a much faster d/l because BT will only see encrypted traffic (which could be anything, like a VPN for example), not torrent traffic.
HTH.
HTH.
This is a good plan. Will it run with Bitlord or should I just switch to µtorrent? I hate typing it out, because I don't have a µ key on my keyboard, and typing out alt + 230 gets grating.
