Hi, i have read some info about the previous attempts of using peltier chips for pc cooling.I seen that there is the low powered usb1 can cooler (lol) just wondering if there would be any benefit in fitting a tube res inside it with whatever mods required to add in your liquid cooling tubes and have the unit outside the pc.
Or to take it further replace the peltier chip with a more powerful one and use a higher powered usb3 cable to power it with also some giant cpu heatsink stuck to the base.
firstly i don't actually need to cool my pc with external reservoirs as i have a cosmos 2 waiting to be built on, it's just for speculation on whether it would serve a use to have your liquid cooling actually cooler than your ambient room temperature, i thought a start would be this can cooler as it has its own unit and is low powered experiment/trial. whats your ideas ??? thank you.
